91 honda accord bake lights
Old 03-10-2011, 08:54 PM
bjfowler6's Avatar
ok im going to try that.... the brake lamp light is on
Old 03-13-2011, 07:39 PM
bjfowler6's Avatar
Default my brake lights do not work
i changed the light bulb n the brake light switch n still my brake lights do not work
Old 03-13-2011, 07:54 PM
I combined all three of your threads, because they are related. Creating a new thread for the same problem hides information about your previous work on the car.
First off, how did you repair the wiring? Do you have a multimeter?
Old 03-13-2011, 08:10 PM
bjfowler6's Avatar
Old 03-13-2011, 08:24 PM
Your light problem is part of your original thread.
Please use that thread so the other members know what you have done and we will not repeat questions.
Here is the link for your original thread with other threads copied in.
https://www.hondaaccordforum.com/for...ad.php?t=38637
Old 03-13-2011, 10:39 PM
bjfowler6's Avatar
i read the book and it says there should be a wire running from the u/h fuse box to the brake light switch...but I do not see the wire could that be the problem
  #17
Old 03-26-2011, 08:01 PM
bjfowler6's Avatar
Default trouble with my brake lights still
Been working on my brake lights for a min now..So far I changed the bulbs, the fuse, brake light switch n yet it does not work....I was told it could be a bad ground thats causing them not to work is that true if so where can i find the ground wire for the brake lights
  #18
Old 03-27-2011, 08:39 AM
None of the rear brake lights work? Is this an auto, if so does the car shift out of park when you press the brake.
I don't have the shop manual for this year so I can't give you the location of the ground but in the Chilton manual I have it lists it as G701. You might be able to google that and find the exact laction.....memory, guess-it is on the rear shelf (by the rear speakers) on the pass side-but don't trust my memory..it is bad.
EDIT: I see now there is another thread on this...Mod's can you merge these or delete this one, looks like more info in the other.
  #19
Old 03-27-2011, 09:23 PM
I just put them all together.
Race4Honda
08-02-2014 01:53 AM
csh217
04-30-2013 09:03 PM
Will.bartlett
02-27-2010 08:44 PM
aznofthe205
04-07-2009 04:04 PM
Aistisval
05-20-2007 05:00 PM
Quick Reply: 91 honda accord bake lights
