91 speedo question
Old 11-04-2007 | 10:02 PM
baylensman's Avatar
Default 91 speedo question
okay had some problems with the charging system. in the course of diagnosis had the instrument cluster out and apart to check the charge light....don't ask.
well got everything fixed so car runs and charges. however the speedometer doesn't work just sits on zero no bounce or anything. cruise works fine.
Did i forget to plug something in? when i put the cluster back together and in??
Could I have dmaged it when i had it out? It seems to be electrical no cable or anything.
Old 11-04-2007 | 10:16 PM
nafango2's Avatar
Default RE: 91 speedo question
check all the wriring again I guess. take apart the cluster again and make sure its plugged in. Check the harness plugs under the steering column. Check the ECU plugs. This type of thing can be hard to pinpoint. especially since you can only check to see if its working or not while the cars in motion.
94accord-lx
07-09-2013 05:18 PM
joe887766
07-21-2012 10:01 AM
lxv5
11-16-2011 09:58 PM
Edinburger
03-09-2006 04:59 PM
gunslingre
03-03-2005 02:37 PM
Quick Reply: 91 speedo question
