92 accord, difficult to start when cold
#21
the book says to first test between the power wire (red/white) and ground then check each wire together.
But actually as long as you see +5 volts between the two that would mean both wires are not broken and working correctly.
I would check ebay for ecu.
Pull yours out and get the code off it and search by that code.
#22
also a question for those on the forum that know more about the 4th gens, since the 4th gen used the f22 and was OBD1 isn't the ECU from a 95 the same?
I have a 95 ECU here that you could have for $25 shipped.
