92 accord flashing D4
Old 01-13-2013 | 02:37 PM
drp92accord's Avatar
Default 92 accord flashing D4
Hello all. This is my first post, I hope that it is in the right forum.
I have a 92 accord with the D4 light flashing. It will crank and drive but it acts like it is stuck in a high gear. I read about shorthing the blue plug behind the passenger side kickplate. When I do that, I get a list of codes. It shows 1, 2, 3, 5, 7, 8, 14.
I don't know what to do from here to get it going. How do I know what to replace or test? Is there a fix that will cover all these codes or will all 7 codes have to be fix individually?
Thanks for your help. David.
Old 01-13-2013 | 02:53 PM
Don't know if this had anything to do with it, but forgot to mention that I just had a front tire replaced and alignment done.
Old 01-13-2013 | 03:38 PM
A lot of transmission related problems for your generation Accord has to do with the Transmission Control Unit (TCU). Pull the TCU and open it up to look for damage inside on the circuit board, such as burnt resistors and blown capacitors.
Honda Electronic Transmission Problem- Troubleshoot, Inspection, Repair, Replace.
Old 01-15-2013 | 07:57 AM
I pulled the TCU last night and looked at it, but I did not see anything that looked bad. What else should I look for or try?
pejaypreston
02-28-2008 01:15 PM
ddold@gkschools.org
11-03-2007 01:51 AM
BlackLizard
07-25-2007 02:27 PM
mbisenius
09-13-2006 12:20 AM
davidk
09-16-2005 02:55 AM
