92 accord no power to fuel pump wont start
I'm having trouble with my 92 accord lx. I thought the fuel pump went out, but it tests fine.
The trouble seems to be that there is no power getting to the fuel pump. I took the main
relay under the dash by the steering colum out and brought it in to my parts store and checked it,
and it was fine. It appears that there is a broken wire or fuse out that I cant locate. The car will run with a jumper wire to the fuel pump and I checked the grounds and that didn't help.
any advise on this one?
thanks, smitty
thanks, smitty
RE: 92 accord no power to fuel pump wont start
You will need to do point to point tests of the Yellow wire from the main relay.
Did you open the main relay and check for bad solder joints?
[IMG]local://upfiles/5417/37C9CB4743B644C3B1DB560702DA9756.gif[/IMG]
ronie1983
02-21-2011 06:26 PM
