92 EX 2dr windows + Rear defroster don't work.
I had just fixed the rear defroster by replacing the fuse. Then it worked for about 30 seconds. The windows are intermittent, and the they work about 1/100 tries. They were working just as I fixed the rear defroster, then they BOTH quit at EXACTLY the same time!! I'm stumped. And I checked att of the fuses, and they're fine. Any suggestions?
Which fuse did you replace, under hood or under dash. 15 and 19 under hood also tie to the windows and defroster, but so much more as well so I find it hard to believe either of those is bad but double check the screw connections to be sure.
From there I'd take one at a time. Windows, try switching the cooling fan relay with the power window relay, easy relay test assuming the cooling fans are working.
From there pull the switch from the door, I only have the 4 dr diagram-key on check for voltage on WHT/YEL, BLU/BLK, YEL/BLK, GRN/BLK -again this is for a four door, hence the four wires, your two door will be a bit different.
rockhoundrob
10-23-2014 09:17 AM
tchestman88
08-20-2013 03:05 PM
