'92 EX Missfireing at highway speeds !?
Old 04-28-2012, 07:25 PM
Alcohol will combine and scavenge water from gas tank, w/i reason. There are additive products that contain alcohol. I have no idea about use of acetone.
Old 04-28-2012, 10:23 PM
Paddlefish's Avatar
Acetone In Gasoline | Improve Your Gas Mileage this is a website I found but I think there are you tube videos that show it too. Will try that egr cleaning this coming weekend . I have a Chilton and I'm not afraid to use it LOL !
Old 04-29-2012, 07:31 PM
Paddlefish's Avatar
Scratch that last idea after reading into the articles it looks like it may not be a good idea after all . It was also suggested that I may have a plugged cat. converter .
Old 05-19-2012, 04:13 PM
Paddlefish's Avatar
Default Update
Well the eye cleaning was a pita, but not impossible. Even changed the coil while I was under there. However not even a mile trip after letting it sit all night got the cel back , any more ideas?
Old 05-20-2012, 07:16 AM
What code(s) are you getting?
Old 05-20-2012, 11:28 AM
Paddlefish's Avatar
Default Codes
Just reset them was getting 12 and 43. How long should it take if the conditions are still present to warrant codes?
  #17
Old 05-21-2012, 11:16 AM
Paddlefish's Avatar
Default After reset and test drive
Now I'm getting code one (o2 sensor a) and 12. Not sure where the sensor is located, car has aftermarket header there is a plugged hole in the tube leading from the the number 2 cylinder. An aftermarket black box with 2 wires coming from it is on the top of the intake. After a google search found it to be a scam attachment to fool the computer into adjusting air intake. My fear is that he may have installed this to circumvent replacing an o2 sensor
SI_dude
11-18-2010 08:39 PM
wackoR
05-04-2008 10:23 PM
thunder_x
11-02-2007 06:11 PM
00AccordLX5spd
03-22-2007 06:36 PM
sanchezcruz_20
01-30-2007 02:43 PM
Quick Reply: '92 EX Missfireing at highway speeds !?
