'92 hard starting at first-start-of-day
Old 07-16-2012 | 11:16 AM
irhunter's Avatar
Thanks Poorman, that is a great link. I think because the CEL works perfectly, it is not the key/switch.
Yes, Texas...my new indicator lamp is wired in the trunk at the fuel pump connector; so, I can see the lamp lit whenever the pump is getting 12vdc. My one and only problem is occasionally the pump is not getting +12v (even when the CEL is on during the power-up process).
Unless someone has a solution which accounts for the fully-functioning CEL and no power to the fuel pump...I'll do the relay job.
Old 07-16-2012 | 05:45 PM
I'd re-solder the main relay. The CEL comes on from the ECU, it doesn't need the main relay to power that lamp. The failure of the main relay is just the circuit that powers the fuelpump. A flaky main relay won't prevent the CEL from coming on for 2 seconds.
Old 07-17-2012 | 10:26 AM
irhunter's Avatar
Jim,
That is what I thought. Will do. Thanks.
Old 10-18-2012 | 05:30 PM
irhunter's Avatar
Final report.
I bought an OEM relay from Majestic Honda, and it solved the problem. Three months of trouble-free starts.
Eventually, I'll re-solder the old one as a back up.
Thanks everyone.
Roy
Old 10-18-2012 | 06:30 PM
Excellent - thanks for letting us know.
19962door
05-03-2014 09:50 AM
hmr
10-20-2013 11:30 AM
Lunalobowolf
10-26-2012 10:33 PM
hmr
04-18-2012 09:11 PM
sthavorn
04-03-2008 08:37 AM
Quick Reply: '92 hard starting at first-start-of-day
