92 honda accord code 9
Old 03-24-2013 | 07:08 PM
Honda717Pa's Avatar
Default 92 honda accord code 9
hey whats up people?
im having an issue i keep pulling up code 9 from my check engine light i was told it could be the distributor. so i went and grab one at auto zone which cost me a pretty penny and the check engine light is still on and i reset it i checked the spark plugs and wires i need help thanks again
92 honda accord lx 2.2
Old 03-24-2013 | 09:34 PM
Code 9 is for the CYP sensor which is inside the distributor. Since a new distributor didn't fix it, the problem is likely a bad wiring connection.
Check for loose/dirty/corroded plugs for the wiring harness. I think in that generation these circuits also go through a big connector near the left-front shock tower?
That's why I always like to suggest testing before replacing parts.
I think the signal wires for those sensors are shielded; just so you're aware before trying to splice wires.
Old 03-24-2013 | 09:54 PM
There is an important ground bolted to the thermostat housing. Unbolt the ground, clean the bolt and eyelet with a wire brush or sand paper, then reattach.
You can test the resistance of the CYP sensor at the distributor and at the ECU. If the resistance is the same, then suspect a bad ECU. A bad ECU is not common, but happens.
Old 04-21-2013 | 08:14 PM
Honda717Pa's Avatar
how can i test the resistance? PAhonda
Old 04-22-2013 | 09:35 PM
Do you have a volt meter to read the resistance?
Old 04-24-2013 | 09:48 AM
Honda717Pa's Avatar
yes i do
Old 04-26-2013 | 09:09 PM
CYP should be the ORG and WHT wires in/into the dist.......what is the resistance between these two wires?
Khai Son
03-15-2012 12:32 AM
Rtherres
01-30-2011 05:58 PM
will'i'am
09-16-2010 02:19 PM
Stener75
07-25-2010 09:21 PM
madsteez
01-18-2009 08:43 PM
