92 honda accord f22 2.2L balance shaft torque spec
Old 12-08-2012 | 01:13 PM
dano2000's Avatar
Default 92 honda accord f22 2.2L balance shaft torque spec
Does anyone know the torque specs for the nut and bolts for the rear balance shaft pulley unit on a 92 honda accord f22 2.2L engine?
I have a manual pdf but I am not finding it after an hour of looking and another hour of looking on the internet.
Thanks for any information and for reading
Dano
Old 12-08-2012 | 01:32 PM
Roader's Avatar
Autozone's repair guides are usually pretty good for torque specs:
  • Apply molybdenum disulfide grease to the thrust surfaces of the balance gears before installation of the driven gear and the drive gear case.
  • Use the 6x100mm tool to hold the rear balancer shaft in place. Install the balancer pulley and gear. Tighten the bolt to 18 ft. lbs. (25 Nm).
  • Pin the front balancer shaft in place and install its pulley; tighten the bolt to 22 ft. lbs. (30 Nm).
  • On the balancer gear case, align the groove on the pulley edge to the pointer on the gear case.
  • Hold the rear balancer shaft in place and install the gear case. Tighten the nut and bolts to 18 ft. lbs. (25 Nm).
Old 12-08-2012 | 01:46 PM
dano2000's Avatar
Thanks I will remember to check AutoZone specs in the future. I appreciate the information.
Old 12-08-2012 | 01:57 PM
dano2000's Avatar
The rear balancer shaft assembly bolts is what I am needing. It was leaking and I replaced the gasket and now I need to reinstall.
I know the water pump is 9 lbs / 108 in and it is a 10mm bolt.
These are 12mm.
Old 12-08-2012 | 02:08 PM
Again, if we are following you 18 ft lbs
Attached Thumbnails 92 honda accord f22 2.2L balance shaft torque spec-4th-gen-gear-case.jpg
Almandino
09-16-2012 11:40 AM
GCMSGuru
05-10-2010 03:34 PM
kris_loehr
11-26-2008 06:52 PM
AbaZ
18
07-16-2008 11:23 PM
rschmitt2
01-06-2007 09:31 PM
