'92 rear passenger steel brake line
Old 08-14-2012 | 12:03 PM
irhunter's Avatar
Default '92 rear passenger steel brake line
Hi,
I have a leak. I've done the search and have found: (1) this is pretty much an awful job, and (2) the line is one-piece from the valve to the wheel.
Well, I'd appreciate hearing from someone who has done the job on a +/- '92 Accord. Hints?
I'd especially like to hear from someone who used the Honda brake line and someone who used off-the-rack universal lines.
What parts did you need to drop to do the job? Anything unusual you ran into? Thanks,
Roy
Old 09-06-2012 | 10:22 AM
irhunter's Avatar
I was away from the car for several weeks...and, now I am back at it.
It now seems: (1) the OEM line is discontinued, and (2) the OEM line runs above the gas tank. So, I would still like to hear from anyone who has replaced the line. Especially for someone using non-OEM lines routed somewhere other than the above-the-tank route,
Thanks,
Roy
Old 09-25-2012 | 03:50 PM
irhunter's Avatar
OK,
FWIW, I did the job and just got a Maine safety inspection. I used universal pre-flared brake line and did a re-route job which avoids dropping the tank (the line now goes aft of the gas tank).
I have pics and something of a write-up. Anyone wanting a copy can e-mail me.
Roy
Old 09-26-2012 | 07:07 AM
Sounds good. Sorry nobody replied, but I guess nobody's had to do this by themselves.
If you want to post a bit of a write-up, I can move it into the DIY area.
cgeromi
03-29-2015 07:13 PM
JonJon13926
07-01-2014 05:45 PM
eduard
05-09-2013 12:11 AM
double b from wv
09-25-2011 05:11 PM
Quick Reply: '92 rear passenger steel brake line
