92 Rear seat removal?
Old 03-23-2007 | 02:55 AM
Dannok
Default 92 Rear seat removal?
Hi,
I've been searching the web for days along with trying everything i can to get the back seat out of my 4dr accord. i cant seem to get it or any information whatsoever. Theres no clips like on most cars i've had. Once i get the bottom section out im assuming the rest wont be hard.. unless in this car i somehow take the top section out first???? I have no idea.
Please help me before i go insane!!!
Old 03-23-2007 | 06:12 PM
deserthonda's Avatar
Default RE: 92 Rear seat removal?
on the side of the upper seat there are 2 cushions, lift it up a bit from the lowwer part and there is a 10mm bolt you need to remove, once out, lift the side cushion up, in the center of the lower seat, there is a 10mm bolt you need to remove , once out, pull the lower cushion toward you and unhook it from the frt slots
overdbars
01-06-2010 07:54 AM
spectre184
06-23-2007 04:30 PM
Cash4
05-20-2007 05:45 PM
Dannok
05-11-2007 12:45 PM
anhvi3t228
03-16-2007 01:54 AM
