93 accord cigarette lighter
Old 08-23-2007 | 02:29 PM
yankeeryu's Avatar
Default 93 accord cigarette lighter
I have a 93 honda accord. The cigarette lighter doesnt work. We checked behind it and it looks good there. I was going to check the fuse, but when I opened the fuse box, there wasnt one labled for the lighter. I checked in my Haynes manual and all it said was "cigarette ligher relay - in left end of dashboard below pgm-fi relay" I have NO idea what that means. can someone help me out here.
Old 08-23-2007 | 03:12 PM
deserthonda's Avatar
Default RE: 93 accord cigarette lighter
chk fuses first..
underhood box fuse # 22 ,,15 amp
under dash box fuse # 11,, 10 amps
if both fuses are good, at cig liter connector 2 wires white/blue chk for power there , should have power and blck wire should have ground there,, if you get both you got a bad cig liter assembly
if you get no power and fuses are ok,, could be a bad relay or broken wiring \\chk this and let us know
if you get no ground at black wire could be a broken wire or poor ground
Old 08-23-2007 | 03:57 PM
yankeeryu's Avatar
thanks! I'll go check thoes right now. Once again a really appreciate the quick replys and good help!
Old 08-23-2007 | 09:46 PM
hondadude's Avatar
if your fuses are all good, you need to open the plastic case attached to the back of the lighter, and resolder the 'pop off' connection.
Old 08-24-2007 | 02:40 PM
Papa Bear
This may be the perfect time to quit smoking
Old 08-24-2007 | 04:09 PM
00AccordLX5spd's Avatar
Registered User
The lighter jack in my 91 Mustang does not work but I know why: there is either a penny or a dime wedged inside of it. I've never felt the need to dislodge it though so it remains. One of my idiot buddies tried to dislodge it with a pair of needle-nose pliers one time. He didn't think todisconnect the battery and I didn't either. He got shocked pretty hard [sm=laughat.gif]
Have you gotten a flashlight out and made sure it is clear of debris on the inside? Just a suggestion.
odabiri
10-27-2011 09:06 AM
jeffersonkim
12-04-2009 04:28 PM
ramachan9
06-27-2009 11:00 PM
BrianH1290
04-15-2008 06:20 PM
latoilette
01-09-2006 03:48 AM
Quick Reply: 93 accord cigarette lighter
