93 Accord, no fire...
I have a 93 accord ex, it has the 2.2L with the automatic trans. The issue I am haveing is when I turn the igniton switch on, the d4 indicator light in the dash will flash and the engine has no fire. This will happen for days, then all of a sudden the engine will start. Sometimes it will start for a few days, then all of a sudden it won't. Trying to track the problem down, I have replaced the following. The main relay, ECM, TCM, coil, throttle body, timeing belt, dist cap, fuel pump/filter. Any help would be greatly appreciated.
The sticky called Common DIY Threads on the top of this forum has a link of checking CEL codes. Count any check engine light flashes for engine codes. Count D4 or S light flashes for transmission codes.
Let us know what you find.
uraceulose
11-06-2010 09:32 AM
