'93 Accord SE - Reprogram Keyless Remote
Old 09-24-2010 | 08:34 PM
Rabbit's Avatar
Default '93 Accord SE - Reprogram Keyless Remote
Battery wore out on the keyless remote. Put a new one in it and, of course, the programming is lost. After googling and searching here, I found a procedure that involved unlocking the doors, turning the ignition "on", pressing the remote button, turning the ignition "off" and repeating 2 more times at which point the locks are supposed to cycle to indicate that the system is ready to be programmed.
I went through this process, but the locks never cycled. I waited 10 minutes and tried it again but with the same result - nothing. When I read these instructions, they were written about a later model Accord. I don't know if they apply to a '93.
My remote is the old variety that has a single activator button. The remote is square and the single activator button is square - if any of that helps.
I would greatly appreciate any pointers. Did I fail to follow the instructions correctly? Are there other instructions for the '93 SE? The Accord has a factory installed alarm/remote key entry.
Old 09-24-2010 | 09:12 PM
I think that procedure is for newer accords.
I would take a look in the owner's manual to see if there is a reprogramming procedure in there.
Old 09-24-2010 | 10:06 PM
That procedure should be in the Helm repair manual. Look in the DIY section for a thread about 'on-line manuals' or something like that.
itboy
06-21-2013 11:07 PM
calamuci1
08-02-2007 07:19 PM
ghettoplaya
06-01-2006 05:25 PM
emaxxman
02-24-2006 10:02 PM
kevinmac59
05-17-2005 11:44 PM
