93 Accord smoking under hood and smell like burning oil
Old 05-24-2010 | 10:05 AM
Pickrng's Avatar
Default 93 Accord smoking under hood and smell like burning oil
Just bought a 93 accord, I'm smelling/seeing smoke oil under the hood after I drive. What is the best stuff to clean the engine so i can see where this might be coming from? Anything I need to protect?
Old 05-24-2010 | 11:07 AM
Simple-Green or water-based degreasers like that work OK for most of it. Then solvent-based degreasers like Gunk for the heavy stuff that doesn't come off with the water-based stuff. Use a ratty old paint brush, or better yet a parts-cleaning brush.
The wiring is mostly protected pretty good, if you don't go nuts. Things to be careful are the fluid reservoirs that have air-vents:
battery
antifreeze reservoir
PS fluid reservoir
brake fluid reservoir
clutch fluid reservoir
Brake fluid gets corrosive when it absorbs moisture, so if you're due for a brake-fluid change (every 2 years) then postpone it for after the cleaning.
Old 05-24-2010 | 11:47 AM
deserthonda's Avatar
open the hood and see if you can spot an obvious leak, if you do, fix it first then clean the engine bay,,,,,,,,,also once engine is clean ,if leak is not obvious ,you can put some oil dye , let it run for a bit and see where dye comes out of
Old 06-01-2010 | 08:59 AM
Pickrng's Avatar
Default Found the oil leak!
Found the leak, to the right of the oil filter? Not sure if there is anything I can do about that, the oil drips down on the exhaust right there thus the burning smell. While I was looking the pan seems to be pretty oily around the bolts, any reason not to try to tighten them some?
Old 06-02-2010 | 08:04 AM
Sometimes if you tighten the pan bolts, the gasket squirms around & leaks more. So be careful.
Is it leaking from the oil filter gasket?
Maybe leaking from the valvecover gasket & running down to the oil filter?
Old 06-21-2010 | 02:20 PM
egebhardt's Avatar
My bet is on the Valve Cover Gasket. $30 and maybe you will need some Hi-Temp gasket sealant.
Old 06-22-2010 | 01:54 PM
Pickrng's Avatar
Default What is this?
The oil leak is coming from a silver "thing" right behind the filter, the filter screws to this "thing". This silver thing has at least one rubber hose clamped to it, I have yet to find this in any exploded view on line, does anyone know what that silver thing is?
Thanks
Shawnzie
11-14-2013 09:25 AM
pouncer11
05-16-2012 09:43 PM
93EXWagon
04-08-2008 05:17 PM
peaty
07-24-2007 08:57 PM
