93 Accord A/T Engine Shaking during gear change
Old 04-24-2015 | 12:17 PM
doncello's Avatar
Default 93 Accord A/T Engine Shaking during gear change
Hi,
I bought an 93 Accord and as you can understand from the title the car is shaking uncomfortably especially when gear is lowered. During increase the shake is not that hard but during gear reduce its pretty annoying. The, rear mount was broken and Ive changed it but still the problem exist. Besides I couldnt find rear mount control solenoid to control mount. Can it be because of that? If thats the case do u guys know where can I get one?
Thx.
Old 04-24-2015 | 04:26 PM
The vacuum controlled valve in the rear motor mount only affects idle vibration performance. Engine motion on downshift suggests front motor mount may be damaged. Less likely are the side mounts but they should be inspected.
If the downshifts are harsh, the trans throttle cable may need adjustment to change shift. Instructions for adjustment are in Honda shop manual. See Online Manuals post links in DIY forum.
Old 04-24-2015 | 04:40 PM
doncello's Avatar
Thx for reply.
We have changed front mount with new one. Ill check that cable and try to find those manuals. Since Im new in forum I am still learning how to use it better.
FITV was broken so Im waiting new one to arrive then Ill check for idle vibration again
d0n
02-04-2013 09:45 AM
sree
10-13-2012 10:42 AM
Carmen91
03-13-2009 03:17 PM
Itzomi
01-08-2009 04:51 PM
88accord
11-10-2007 10:01 AM
