93 Honda warm idling problem
I have a 93 Honda Accord, with carburettor and 1.8 ltr engine. The car starts good from cold (usually after 2 cranks) but if I travel maybe 2 miles then stop the car get out do some shopping for 10 min and come back the car starts but a very low idle causes it to stop. Anyway I get the car running, and it runs good.
This only happens when the engine has been warmed up, if I start the car from cold, stop it and start again - no problem. If I take the car out for long run of maybe 20 minutes - no problem. This only occurs in the short trips. PS recently changed air filter and oil, oil filter (this shouldn't have caused this problem?)
Thanks
Thanks
Sure sounds like a choke issue.
2nd approach: try an operational change of morning ritual before working hard on this:
maybe let car warm/idle for 5 min in driveway as you are getting ready 1st thing.
That's a good suggestion - lubricating the carb linkages hasn't helped. This happened again last night, but the choke flap was open to its maximum position. The idle becomes very low then it just dies.
The flap was closed when cold, but when the car idled off when warm I took the air-cleaner top off and could see the flap was as open as it could go. This problem started when I replaced a very worn air-cleaner element with a new one, so I'm thinking it might be something to do with the air/ fuel mix. Anyway, I'm going to try your suggestion ASAP.
Thanks
Thanks
Are the battery and alt good? I ask because I know the 3rd gen carb'd models will "race" rpm's if there is a charging issue.
tonybennettnz
09-16-2008 12:20 AM
tonybennettnz
09-02-2008 08:21 AM
banjuju
04-12-2007 05:35 PM
