93 honda will not start till i spray carb cleaner in the airfilter
Old 07-30-2012 | 01:20 PM
biggame's Avatar
Default 93 honda will not start till i spray carb cleaner in the airfilter
i have a 93 honda accord that will not start without spraying carb fluid in the airtake.then it runs till i turn it off an it cools down,an wont start? but when i do turn it off it will start when its hot ,but when it cools down it wont start till i spray more carb cleaner in it? what do i need to look at too fix this problem?ty john
Old 07-30-2012 | 09:15 PM
Check for codes first.
When trying to start "stone cold" does the cranking "sound" the same as when warm? Or does it seem a bit slower?
Old 07-30-2012 | 10:31 PM
Silver6gen's Avatar
that indicates a fuel issue. Either you are not getting pressure to the rail (fuel pump issue) or your injectors are not getting the electrical signal to inject.
Daily Cruiser
05-10-2012 09:41 PM
tonymazarati
03-30-2012 07:28 AM
Max Utility
11-22-2010 02:01 PM
MrGmo
01-06-2009 07:02 PM
