94 accord 2.2 auto trans 4dr
Old 04-19-2013 | 05:01 PM
donwon's Avatar
Default 94 accord 2.2 auto trans 4dr
I put a junkyard trans in and am trying to adjust tv cable because it shifts hard and there is no slack in cable to start adjusting from.is it possible that the trans I put in had different arm which requires longer cable? Because you have to pull arm up couple inches just to get cable on and there's a lot of pressure already on it ? It's already like half way up ?
Old 04-19-2013 | 05:18 PM
Please do not post questions in the DIY Section.
I've moved this to General Tech.
See if this will help, if not let us know.
Attached Thumbnails 94 accord 2.2 auto trans 4dr-5th-gen-throttle-control-cable.jpg
Old 04-19-2013 | 07:53 PM
donwon's Avatar
The adjustment is way off .I have to pull arm up almost all the way just to put cable in arm .it's like the cables to short because the adjustment starts with arm halfway up with cable all the way down ?
Old 04-20-2013 | 10:31 AM
So lock nut "A" is threaded all the way up the cable? Got a pic of the cable end?
Old 04-20-2013 | 02:45 PM
Roader's Avatar
Do you still have the old transmission? Compare the two arms. Ditto Poorman's request: pic's would be nice.
The more slack in the cable, the harsher the shift, so it may not be the cable causing harsh shifts. Are the NM & NC speed sensors clean?
donwon
04-20-2013 09:56 AM
quassu77
10-21-2011 02:04 AM
heiner921
08-25-2010 01:18 AM
NateDogg
07-13-2009 07:21 AM
LSU99
04-03-2008 03:57 PM
Quick Reply: 94 accord 2.2 auto trans 4dr
