94 accord blows coolant hoses
Earlier this week the bottom rad hose had a hole so I replaced it and last night my temp started to move up and I shut the car off to see the top rad hose leaking. I changed it today along with a new cap bled the system properly and added coolant. Drove around temp was good no leaking. Came to a red light and seen smoke from my hood coming from radiator area. Nothing's leaking just smoke. I let pressure out by losining te rad cap and heard bubbling in the resivoir. Bad radiator or something else ?
If temps are remaining normal, keep an eye on it, then the steam could be from the "left over" coolant under the hood....that stuff will spray every where.
Again, I'd run it more to steam off the fluid, keeping en eye on the gauge.....and drive.
If overheating during stops, suggest changing the thermostat. Sometimes they will constrict opening at speed to maintain temperature, and then fail to open when stopped leading to overheating.
