94 Accord Brake Rotor Resurfacing
Does anybody have a good estimate of how much it should cost to resurface the front brake roots on a 94 Accord? According to the manual, they must be turned on the vehicle since they are bolted from the knuckle. Of course that means going to the local Honda stealership and bending over. The cheapest price I've found in my area is $179.
It depends if they can be turned or not. If they're so far worn, you may just want to invest in new rotors. If you can take the rotors off yourself, you can just take them to a parts store and have them turned there.
If you can't take them off, any shop can do it, but they're likely to shear the bolts holding the rotor to the hub.
aznofthe205
02-11-2009 07:15 PM
J2Performance
01-15-2008 05:29 PM
