94 accord d4 tcm code
I think that the brake lamp turns when there a difference between resistance between the bulbs is detected by a sensor on the driver's side tail light. You should download that shop manual and clean the appropriate grounds. G551 and G501. Those are in the trunk. The shop manual will show those locations.
You may want to remove the brake bulbs and make sure there is no corrosion on the connectors or that the bulbs are not loose.
appleman
09-27-2007 11:44 AM
