94 Accord EX auto tranny problem
Old 03-02-2007 | 07:50 PM
firepilot
Default 94 Accord EX auto tranny problem
Transmission was working just fine, until sunday night when I noticed it was staying in gear
quite a bit longer before shifting. Next time I drove it, slipping was noted. Next day, I could hardly
get it up the driveway. Slips quite a bit in forward gears, or stays in gear up to a high RPM. At
idle, will not even engage when I put it in drive.
However, it seems to shift into reverse just fine.
Recently replaced CV axles, fluid looks fine. I have high miles, 225K and engine runs
great. Transmission was replaced at some point before I bought it at 170K. It seems
automatic transmissions are not exactly Hondas forte, based on some online reading.
Also had just replaced valve cover gasket (again since I botched it the first time and dripped a lot of oil
from the valve cover due to not sealing it up well)
No check engine light.
Old 03-03-2007 | 10:20 PM
hondadude's Avatar
Default RE: 94 Accord EX auto tranny problem
try jumpering the service connector and look for a 'D4' flash code;
http://members.troublecodes.net/hond...ice%20conn.jpg
Drain and refill the trans with fresh Honda Z-1 ATF. [3 Quarts]
Beyond that, if you have no flash code, there is probably a stuck valve in the valve body of the trans.
Old 03-04-2007 | 07:55 PM
firepilot
Thanks, I am going to work and look for a D4 code. What are symptoms of a stuck valve and how is it fixed?
Auto transmissions are a bit of a enigma to me, they might as well work by PFM.
bigtex
02-21-2018 12:08 PM
hondanut85
05-13-2011 01:47 PM
shissir
09-04-2007 04:54 PM
dejavu247
12-04-2006 08:50 PM
ian30
05-23-2006 11:00 PM
