94 accord ex sohc vtec swapped to a 96 f22b sohc vtec i need a quik response pls thx
Old 03-17-2008 | 04:10 AM
kangas's Avatar
Default 94 accord ex sohc vtec swapped to a 96 f22b sohc vtec i need a quik response pls thx
i ran into a problem ok i did the swap my 94 accord ex the motor is out of a 96 f22b sohc vtec this morning tuning a lil took it around the block maybe a mile my car didnt go into d4 overdrive instead it felt like i hit a govenor no response ..... then it died " i ran out of gas " next i get it home replaced the fuel then the car started acting funny a mild studder flashin inst. panel d4 light stayed on while in park/also check engine light cranks fine/ runs for a second then starts the studder like no fuel to motor rember it was just running fine 10 mins beforei need help is it a sensor or fuel problem preventing the overdrive? did i for get to hook something up?it has to be something simple it was running so damn sweet so sweet
Old 03-17-2008 | 06:56 AM
BlkCurrantKord's Avatar
Default RE: 94 accord ex sohc vtec swapped to a 96 f22b sohc vtec i need a quik response pls thx
Do you know how to type or think in complete thoughts/sentences. I barely understood that.
Pull the code that you're throwing.
Old 03-18-2008 | 04:47 AM
kangas's Avatar
well i didn pull any codes none nothing came up? obd1 nothing i did find 2 plugs on the tranny that didnt clip now worried about the fuel why am i not getting any i did run out of gas what is the easiest way to go about getting it to run right? pull the fuel rail clean it out? change the fuel pump what to do i got rid of the d4 problem now like i say it is just a fuel problem
Old 03-18-2008 | 11:55 AM
00AccordLX5spd's Avatar
Registered User
The problem could be related to the fact that your 94 EX was OBDI and the 96 EX is OBDII. Did you retain the same ECU from the 94? If so, you are probably going to have to get an OBDII ECU to make it function properly. Or you'll have to do some kind of OBDII to OBDI conversion.
Old 03-21-2008 | 02:29 AM
kangas's Avatar
thx u have been alot of help i will let you know
rederik13
03-02-2014 07:25 AM
rederik13
02-27-2014 10:35 PM
desert_accord
08-11-2009 06:56 PM
PTVDesign
10-28-2008 09:20 PM
stanley.ysf
08-23-2007 07:42 PM
Quick Reply: 94 accord ex sohc vtec swapped to a 96 f22b sohc vtec i need a quik response pls thx
