94 Accord EX speedo not working
Old 10-08-2011 | 01:53 AM
LucKy_FeRg13's Avatar
Default 94 Accord EX speedo not working
hey ive got a 94 accord ex and the speedo stopped workin. i think it may be the vss or maybe a wiring issue or tranny filter i really have no idea and i need some ideas. PLEASE HELP lol thanks guys
Old 10-08-2011 | 08:53 AM
Is the milage (odo and trip) still working, does the cruise work when the speedo does not.
Also check for codes in the ECU and TCU.
At the top, Common DIY Threads there is a link to a shop manual that will help with testing the VSS and the wires.
Old 10-08-2011 | 09:56 AM
Do you have a Check Engine Light (CEL)? If no CEL, it probably is the speedo circuit board instead of the VSS. Also, a faulty VSS or VSS wiring connection will also cause the cruise control to not work (however, some problems with the cruise control wouldn't always necessarily point to the VSS).
See this link:
honda-tech.com/showthread.php?t=2460328
Old 10-08-2011 | 08:33 PM
idk if the cruise works bc i live in houston and i never get to use it lol but the cel only comes on when im driving and i floor it. also the idle surges when i let off the gas but if i put it in neutral and gas it a lil it stops surging
Old 10-09-2011 | 08:39 AM
Check the codes, if you don't know how there is a link in the Common DIY Threads that will help you.
Does the odo and trip work? Want to know this so the issue can be figured out (VSS or PCB or other).
Old 10-10-2011 | 03:13 AM
yes both the odo and trip are working. and i will check the codes asap but working 3rd shift and having a 1yr old daugter make it a little difficult lol. i really appreciate all the help ive received so far
Old 10-10-2011 | 02:06 PM
It probably is the speedo circuit board.
Old 10-10-2011 | 03:32 PM
correction the speedo and odo aren't working just noticed today when i was taking my daughter to the doctor. so would it be the vss then?
Old 10-10-2011 | 03:44 PM
May still be the speedo. As long as your Check Engine Light bulb is not burnt out and you do not have a CEL on, it probably is the speedo. Checking for trouble codes would reveal if there was a VSS problem.
The odometer and trip meter sometimes gets stuck on those Accords, as it was mechanical. Try pushing your car key several times in the maintenance required reset slot on the instrument panel to see if the odometer and trip meter works again.
To recap, if you have a CEL and trouble code indicating the VSS, then it probably is the VSS. Otherwise, this maybe a problem with the circuit board on back of the speedo head, a common problem. Refer to my post and link above if it turns out to be the speedo.
Old 10-10-2011 | 03:46 PM
There is a blue Service Check Connector under the passenger side dash that you can jump with a wire to check for trouble codes if your Check Engine Light is on.
See this link for a picture of the connector under the glove box and instructions:
ht-archive.com/showthread.php?t=2703528
