94 accord ex squeaky front end
Old 01-25-2011 | 10:03 PM
aborbonio's Avatar
Default 94 accord ex squeaky front end
I have a 94 honda accord ex sedan and my front end on the drivers side is squeaking really bad when i turn the steering wheel both ways and when going over the slightest bump. When the car is off it does it too.. i can press down on the car and it squeaks.. i lubricated the front end but still squeaks any idea what it could be.
Old 01-25-2011 | 10:38 PM
What did you lubricate on the front end? Don't forget the anti-roll bar bushings. What about sticky/noisy ball joints? Radius rods?
Old 01-26-2011 | 05:18 PM
diyorpay's Avatar
On my 93 Accord those old bushings were the culprit. The squeak was particularly bad in cold weather and made me feel like I was driving an old jalopy. I now spray them down with silicone at each oil change and it keeps them quiet. This Spring I plan to replace them. They still do the job but are old and cracked pretty bad.
Old 02-02-2011 | 09:10 PM
aborbonio's Avatar
Default 94 accord lower ball joint
so i went to my mechanic and got new shocks and upper controlarm and my sway bar bushings but my squeak came back i met a guy same exact car he told me his did the same thing its the lower ball joint front.. but my mechanic wants to charge me $224 labor 2.4 hours the part is only $15 my mechanic is kinda pricey does any body know if this sounds about right
Old 02-02-2011 | 10:54 PM
Well tell him he's much to pricey..A mechanic getting $93.00 per hour is Highway Robbery. Tell him you'll give him half of what he wants in cash and then he wont have to pay tax's on it and see if he bites...
Yes, that's what I would do...
Old 02-05-2011 | 11:44 AM
HondaNatey's Avatar
It is the lower ball joint. The same thing happened to me. I shot some grease in the boot of it which stopped the squeak for a couple months, but after heavy rain it came back. You can either keep shooting it with grease or replace the part. If you do one side, I would recommend doing the other as well. Things tend to wear in the same time frame.
Old 02-25-2011 | 10:11 PM
94HondaAccord's Avatar
I would say lower ball joint as well. get it on a lift with all the wheels on flat surface and listen with a sthethoscope
eazycash
06-04-2012 08:59 PM
SilverCityAccord
03-04-2008 03:46 PM
unir2b1
01-29-2008 12:16 AM
indy49
12-07-2007 10:17 PM
hongu
06-08-2005 10:38 AM
