'94 Accord EX VTEC runs rough between 2700 and 3000 RPM
Old 08-27-2013 | 09:47 PM
curmudgeon's Avatar
Default '94 Accord EX VTEC runs rough between 2700 and 3000 RPM
I have a '94 Honda EX VTEC 175K miles with 4sp automatic transmission
It runs rough between 2700 and 3000 RPM. By rough, I mean It vibrates or shakes.
  • This only happens when transmission is in gear (doesn't happen when transmission is in neutral)
  • This only happens under moderate acceleration (doesn't happen under full acceleration)
  • The symptoms get worse as engine temperatures rise.
  • The vibration can be felt through the seat, not through the steering wheel
  • The transmission has been checked by a professional since after the symptoms began
  • Both front axels have been replaced since symptoms began
  • Spark plugs and wires have 30K on them
  • Recently, it has started running rough at 2000 RPM, too
All four injectors register 1.0 Ohm resistance. Haynes says resistance should be between approximately 1.5 and 2.5 ohms. I have also read that the exact resistance is not as important as the fact that all four have a similar figure.
Your thoughts will be appreciated
Old 08-28-2013 | 12:43 PM
I've moved this to General Tech - please do not post questions in the DIY section.
Sounds like the EGR ports (ports not the valve) are clogged. There is a how to in the stocky at the top of this section.
Old 08-28-2013 | 01:03 PM
This has similar symptoms to my 94EX long running problem w/ vibration under acceleration. I replaced both axles twice w/ AZ aftermarket axles. Symptoms remained same. After 2nd AZ axles, I purchased Raxles replacements and solved problem.
Also suggest inspecting motor mounts for damage. It is possible that motor mount damage could cause these symptoms.
Old 08-31-2013 | 12:02 PM
curmudgeon's Avatar
What are AZ axles? Raxles?
What should I look for on the axles besides defective boots and excess play?
Old 08-31-2013 | 12:36 PM
AZ= AutoZone
Raxles= Brand/company that sells cv shafts
TX is with the cv shafts. I'm with an egr port issue.
HighwayStar
06-15-2015 11:18 PM
andrewb901
01-07-2014 08:01 PM
Jeff 1990 Accord EX 2.2L AT
02-22-2012 08:17 PM
Accord Pete
01-31-2010 03:50 PM
Cusm2012
03-23-2009 07:01 PM
