94 accord idle/acceleration issues
ok so me and my little brother where messing around on this abandoned stretch of road, we did 2 quarter mile runs in my 94 Honda accord, cd7 with f22b1 vtec.
never red lined it or anything like that as we went to stop after the second run the rpms stayed about 3000rpm and when i gave it a little gas it dropped below idle and was between 500-1k at idle bouncing around not fast tho. then we went to come home on the highway and in any gear the car starts to like rock/bounce/hesitate when NOT pushing the gas at about 2200rpms, not real hard but enough for you to notice the issue then when you put it in neutral the rpms climb back up to 3k rpm for about 10-15 second and then drop back down. any ideas? there's no weird engine noise, no CEL.
update: when u start off in first and floor it theres no get up and go, it goes just not as fast as it use to. same with all the gears
plugs, wires, rotor, coil pack, distributor evrything its brand new and the engine coolant is full in res and in the actually radiator. just cleaned egr valve and ports last month.. tps is new and has been calibrated aswell
update: the car when in neutral stays about 2500 to 3000 rpms unless at a full complete stop, and when your driving and the rpms come around 2500-3000 rpms it wants to stay in that range..my uncle used some smoke machine to fill the motor with smoke to check for leaks, and there wasn't any leak. its 5 speed
update: i unpluged the TPS and car runs fine, i am guess that was the problem..will replace and update
well, try going to a junkyard and grabbing a new tps or buy a new one, if that doesn't solve it permanently keep checking.
