94 accord lx tps voltage
i replaced the tps on my 94 accord lx . when i tried to calibrate it the voltage stayed at 2.8volts. replaced that tps with another new tps and its reading 2.9 volts.does that signal come from the ecu? im at a loss here. i had the head rebuilt after that is when the tps code appeared.
Ok, what wire colors are on the 3-pin connector at the TPS? What wire are you connecting for the Red + volt meter lead? What wire or other location like - battery terminal are you connecting the black - volt meter lead for ground?
tps voltage
sorry had an emergency out of state that why my reply is so late. with my meter ground connected to neg, on vehicle battery i read (closed throttle) white wire 7.0v,
red wire2.5v, green wire2.0v wide open throttle white 6.8v, red 6.22v,green 1.86v
Please verify the wires colors to the TPS:
grn/blu, red/blk, and yel/blu.
It is possible to switch the map and tps connectors. Map wire colors are:
yel/wht, grn/wht, and wht/yel.
Your voltage readings don't make sense. Test your volt meter across the battery terminals to ensure you read 12V.
