94 Accord Vtak Solenoid Leaking
The Vtec Solenoid gasket is leaking and from what I have read its fairly common esp with high miles. I sprayed some carb cleaner around it to get the oil out of the area and sure enough its leaking out of the top pretty bad. The part is also hard to find I guess, but I managed to find one on ebay for 20 bucks. Before I buy it, I want to double check that it is indeed what I need.
OEM Honda Accord EX LX 4 Cyl F23 F22 Odyssey Acura CL VTEC Solenoid Gasket (P0A) | eBay
Well, there are two o-rings, that is the "lower" o-ring.....why not try the top o-ring, since you say that is where it is coming from?
pn 36172-P0A-005
EDIT: Online Honda dealers, you can get BOTH o-rings for ~$10 ?
pn 36172-P0A-005
