94 accord won't rev past 2k
Old 09-23-2012, 01:07 PM
Are you sure that is an "8" and not a "6".
Also see this link for getting the codes....https://www.hondaaccordforum.com/for...threads-40780/
If the CEL is on, then the car will go into "limp" mode and will do just what you are describing. Need to get the code and resolve the issue.
EDIT: Here is the link to the VIN Decoder I was talking about : https://www.hondaaccordforum.com/for...r-members-use/
  #22
Old 09-23-2012, 04:34 PM
Slidesquad240's Avatar
I swapped out the tps sensor with another one and it seems to run a lot better now
  #23
Old 09-24-2012, 08:29 PM
Get the codes...please?
  #24
Old 09-24-2012, 11:55 PM
AccorDats's Avatar
Thumbs up
OT:
I salute you sir for genuinely helping us out in this forum.
  #25
Old 09-25-2012, 09:01 AM
Not sure how all I seen was to put a paper clip in the blue plug there's 2 blue plugs next to each other ?
  #26
Old 09-25-2012, 06:29 PM
It should be the one with two wires.
  #27
Old 09-25-2012, 06:31 PM
You want to short the plug with only two wires going to it (the other one has 3).
  #28
Old 09-25-2012, 08:06 PM
Ok I'll do That sometime tomorrow and get back to you
  #29
Old 09-28-2012, 04:42 PM
Well great news I registered the car and did a few test drives only to see it puffing white smoke and the oil turned out milky so I'm guessing it blew a head gasket
  #30
Old 09-29-2012, 09:29 AM
Ouch.....a compression and leak down should confirm. Of course if it is bad enough, pull the rad cap off when cold, start engine and look for bubbles in the coolant.
Cody_754
03-08-2024 10:34 AM
M-train
02-27-2015 06:55 PM
BrandoSATX
07-03-2013 12:11 PM
argarcia86
03-17-2013 08:28 PM
blakeryanfarris
12-06-2012 12:13 PM
Quick Reply: 94 accord won't rev past 2k
