94 Honda Accord Fuel Pump Replacement
Hi everybody. My fuel pump may die anyday now and was wondering where
is access to tehe fuel pump to replace it? Is it under the backseat? Or
do I actually have to drop the tank? I had hell trying to remove the backseat
mat, it's clutched in pretty good and wanted to know for sure before
removing it. Any help will be appreciated.
A few choices......drop the tank or cut a larger opening
https://www.hondaaccordforum.com/forum/general-tech-help-7/anyone-cut-their-own-fuel-pump-access-41535/
Kind of rare that they fail. What trouble are you having and what tests have you done? One of the first ones would be to test if you are getting voltage to the pump....which means you would have to have found the access to the wires going to the pump.
I ran out of gas a couple of times which I've heard that's bad for the fuel
pump regulator because pollution gets in the tank. Every other day I get
a stalled acceleration and sputtering sounds from the back of the car. Like
it's struggling to get fuel.
You do not need a fuel pump.
Is your check engine light on?
Even if it is not go ahead and pull the codes using the 2 wire connector under the glove box.
There is a good write-up in the DYI section of this Forum
I've had the car for 2yrs and I've never had a tune up as long as I've had it at 140k miles.
I swear that spitting, coughing, sputtering sounds comes from the back trunk area under
the car. It happens at normal temp on any given day. I will check crispin is referring to
and will respond later this evening.
Yeah the fuel pump really isnt a fun job in the 94-97 accords. considering to do it right you have to take the gas tank off. Which if your from somewhere where it snows and salt is used its likely the whole underside is rusted and will make the job that much more fun.
I looked at the wiring and I am totally befuddled to what I am looking at lol.
I think I will take a chance and change out the fuel pump because it's the
original anyway, it's a 94 accord. And that loud sputtering sound coming
from the gas tank while stalling sounds like a faulty fuel pump to me. I will
take a chance on this! I've read someone say that it's an easier way besides
dropping the tank that you can access the panel from the backseat or from
inside the trunk. I completed this job with my 2001 corolla from the backseat
and it only took me 20mins lol. Please tell me it will be as easy with my
94 accord. All I did was lift up the backseat, had no trouble with the
corolla.
corolla.
