94 Honda Accord lx
Is the car not running?
A code 15 is an issue with the ignition control module circuit. This is also known as the igniter.
Technically the problem can be with the igniter, electrical/wiring, the coil, or the ECU.
The most likely culprit is the igniter, but I would remove the distributor cap (keep the spark plug wires attached, so you don't mess up the firing order). Look for any obvious corrosion on the connections to the igniter.
