94 LX-Oil soaked spark plug cyl.2-need help
Old 06-13-2011 | 08:40 PM
9foaccord's Avatar
Arrow 94 LX-Oil soaked spark plug cyl.2-need help
Oil keeps fouling out my cylinder#2 plug. I've changed the valve cover gasket and rubber spark plug seals, still soaked. I did some research and found out thta there are 4 more seals somewhere under the rocker arm assembly. Is there a how-to on replacing these seals? where can i order them? Haynes manual is not giving too much detail. Any help would be appreciated.
Old 06-13-2011 | 08:45 PM
Google wYU8qtPzQOY
This is a video on replacing those lower seals.
Usually a fel-pro gasket set will have the upper seals, lower seals, bolt grommets, and a new valve cover gasket. If you can't buy just the lower seals aftermarket, the honda dealership should sell them.
wannakeepmy94Accord
03-14-2012 09:06 PM
riverman
01-13-2010 10:35 AM
offroadTRD
07-03-2009 07:38 AM
mfre1111
02-07-2008 11:44 AM
Busareds
10-02-2007 10:01 PM
