95 2.2VTEC auto boggs down
Hi all. 95 Accord EX with the 2.2VTEC and an automatic. When cold it runs and drives great. Once it warms up is is when I start to have problems. No problem in 1st gear but when it shifts to 2nd, it will bogg down and misfire. Once it hits 3rd, it seems to straighten out a bit and 4th we are more or less back to normal. Plugs, wires, cap and rotor all new within 1500 miles. Am thinking EGR but wanted to get some other opinions. Any help or ideas would be appreciated. Thanks in advance.
I'd check for codes just to be sure. Also we are assuming the light is working, there is a bulb check when you first turn the key to the "on" position...it should come on for 2~3 seconds and then go off.
If no codes, I hate to guess and throw parts at an issue. O2 Sensors can get lazy without setting codes and being OBD-I there isn't much live data to help.
Yes the light is working. I hate to just throw money at an issue as well. I had someone else suggest converter but you would think that it would be an issue all the time and not as described. Does anyone think a simple vacuum leak would cause this type of problem?
Yes, there are a number of things that could cause the issue.
I would venture that a vac leak would be showing itself with other issues - high idle, "hunting" idle, ect.
Converter is not very likely based upon the description you are giving.
I wish I could give you a simple answer but a no code drive issue on OBD-I is not a simple thing.
For giggles, try unplugging the O2 sensor wires. This is still not a true test as the ECU will go into a "default" mode but may shed some light on the issue.
I would get it warm, and acting up, at night. Spritz water around the engine compartment looking for arcs.
Coil?
Roy
Just checked for any codes. there were none. As for plugs and wires I did use aftermarket cap rotor and wires but NGK plugs. Have about 1500-2000 miles and no issues until a day or so ago. Just after I filled the tank.
Will have to do some more checking as far as vacuum leak. It does have 223000 miles and looks like most of the hoses are original.
I will try unplugging the o2 sensors and see what happens.
Thanks all for your help
