95 Accord A/C LOW IDLE
Old 07-15-2006 | 02:25 PM
scottymx
Default 95 Accord A/C LOW IDLE
New to the forum and need some help. I have a 95 Accord with a 2.2 non V-tec with auto trans, Car runs, drives and idles very smooth except for when i turn on the A/C, the idle drops about 300 rpm and starts to vibrate a little but clears up fine if i press on the throttle to bring the idle up. ( but the A/C cools fine). Idles very smooth at 750-800 with A/C off.
Anyone had this problem? Would this be controled by the IAC? if so can i cleen it, carbon? or is it all electronic?
Thanks in advance!
Scottymx
Old 07-15-2006 | 04:17 PM
lightshow's Avatar
Default RE: 95 Accord A/C LOW IDLE
probably if you just turn up the idle a little it will be fine. the screw is on the top of the throttle body
Old 07-15-2006 | 07:28 PM
scottymx
Thanks for a quik reply, however i think That would be a temp fix, the computer/ECM will set the idle back down in time. Something is suposed to increase the idle when the A/C is turned on, i'm just not sure what?
Scott
Old 07-16-2006 | 01:55 AM
The idle air control valve (IACV) is supposed to hold the idle when the AC engages. That's also what the ECU will use to bring the idle back where it should be. The IACV is on the back of the intake manifold. But it works best if the base idle is set correctly.
You should set your base idle, the procedure goes something like this:
1. Warm up the engine.
2. Turn off all accessories & loads.
3. Unplug the electrical plug of the IACV.
4. Adjust idle screw for **??** RPM.
5. Turn off engine.
6. Reset ECU.
7. Start engine & let it run for 10(?) minutes without touching the gas pedal.
*Find a repair manual for YOUR YEAR because in step 4 you're NOT setting the normal operating idle speed. For example my '95 Integra you were supposed to set 450 to 500 rpm. Then after you plug it back in & reset the ECU, the idle goes back to 750 where it belongs. I don't know whether 500 is the correct setting for a '95 Accord.
Old 07-16-2006 | 03:37 PM
scottymx
Thanks JimBlake! I removed the ( IACV) it has 2 ports, one side has a screen, it was carboned up. I cleened it up and followed your steps and WOW works perfect!
Scott
Old 07-16-2006 | 03:43 PM
deserthonda's Avatar
ORIGINAL: scottymx
Scott
glad you got it fixed... you can rely on JIMBLAKE he knows his stuff..
Old 07-16-2006 | 04:25 PM
ORIGINAL: scottymx
... WOW works perfect!
Scott
It's always nice to know how it turns out.
Old 07-16-2006 | 09:11 PM
ORIGINAL: JimBlake
ORIGINAL: scottymx
Scott
I wish every member here would let us know with the fix after they have asked for help and got some advices
CD7jay
10-28-2009 02:11 AM
ItsNewToMe
05-03-2009 08:20 AM
Nitin
04-20-2008 08:19 PM
HondaAccordNewb
10-18-2007 07:51 AM
thunder_x
09-25-2006 10:34 AM
