95 accord ex, ABS light, question
Its for a 95 accord ex 4cyl auto, My Abs light comes on after a minute of driving, i checked my brakes and they are still good, my brakes sqeeks just a little. The brakes is just functioning the way it should be (i think), what could it be? is it my sensor? if it is where do i find it and fix it? is it expensive?
Thank you
Neiser
Thank you
Neiser
RE: 95 accord ex, ABS light, question
Since your other post is about the CEL & VSS problem, they are probably related.
When you jumpered the connector to read the CEL blinking, the ABS lamp should have also been blinking its own code. What was that?
I think the ABS will also throw an error if it cant see a good signal from the VSS.
Autozone won't be able to help w/ an ABS code. It can only be extracted manually same way you extracted CEL code, but reading the ABS light flashes. All short flashes separated by short pause so ffff-p-ffff = 4-4. Post code for help.
ABS has its own syntax of flashes too.
Long flash & long pause = not part of the errorcode yet.
short flashes = first digit of 1st error code
short pause
short flashes = 2nd digit of 1st code
long pause
short flashes = 1st digit of 2nd code
short pause
short flashes = 2nd digit of 2nd code
long pause
(I dont know how many codes can be stored)
then they repeat...
short pause
long pause
short pause
long pause
then they repeat...
93Accord2.2
11-07-2013 08:10 AM
mickey4live
07-06-2012 09:29 AM
