95 Accord EX, Cel Codes, How can i fix it
DIY cell codes that i found out (95AccordEX, 4cyl auto) D4 blinks 4X fast(could be the transmission), CEL 1 fast and 7 long (VSS (Vehicle Speed Sensor) defective circuit or unplugged/defective sensor), how can i correct these problems? is that hard to replace? is it expensive?
thank you very much,
neiser
neiser
RE: 95 Accord EX, Cel Codes, How can i fix it
It is pretty easy to replace. The VSS is bolted to the tranny with 2 or 3 bolts. The VSS is located on the tranny in the are below the distributor. You just have to unplug the connector, unbolt the sensor, and put the new on it. There is a drive link that sits in the tranny that you want to make sure that you don't lose.
A new speed sensor from TAS auto is ~$100 that is a honda sensor. You can shop around for aftermarket parts as well.
You should download a 94 shop manual from one of the links in the online manuals thread in the DIY section, or the ACC 5th gen.. has the shop manual in pdf form.
