95 accord ex rpm red lines at 5000
i have a 95 honda accord ex it was automatic but i installed a f22 vtec engine and manual transsmision from a 97 honda accord ex and i changed the wiring harnnes because it was driffent but im using the the computer from the 95 automatic accord the computer is P0A and the car red lines at 5000 rpms, i installed a mugen chip they tollme that if install this chip i was going to be able to red line at 8500 but it didnt make any driference it all,, i tryed a ecu chiped from a civic P30 and the car was missing alot but the rpms went all the way to 8500 and the vtec was strong at 4500 but the car doesnt stay running.. and i tryed a ecu from a h22 and doesnt work, a one from a acura gs-r and gs, and one from a 92 honda accord but nothing seems to work good ....i been looking from ecu for 95 acccord ex manual transsmision but they said its the same from a auto to manual transsmision .does any one knows what i need to make my car running good, what ecu can i use that works on my car because i have a turbo ready to install but i dont install the turbo kit if the car is running like this..
There is a jumper that you will have to remove to make the ECU not look for a transmission control unit. You 95 AT ECU may put you into limp mode since it sees no TCU.
I read about that over at pgmfi [dot] org
