95 accord f22b1 running rough with occasional CEL
Old 05-02-2011 | 01:02 PM
Tek310's Avatar
Default 95 accord f22b1 running rough with occasional CEL
It had been starting to throw a code off and on, after start up or after I put it in gear. Would chug acting like it wanted to die off. The CEL would come on and it would start driving normal again.
Well today I drove to run some errands got home then went out to do something else and it cranks but won't start. It starts up for a second then dies instantly, even with my foot on the gas pedal.
Here are the codes I picked off of it
22 VTEC pressure valve
And
9 CYP - cylinder sensor
Are these legit? Could they cause my problem?
Where can I get a new vtec pressure valve? Mine is all rusted up and the plugs is all beat up.
Distributors hard to install? I was told that may need to be replaced or the main relay. Is the main relay located inside of the distributor?
Old 05-02-2011 | 08:20 PM
distributor is pretty simple. Check that your vtec plug is making good contact with the pressure switch.
Old 05-02-2011 | 09:33 PM
ahh,,,,,,seen this somewhere before. deja vu.
As stated before, mark the dist to the head. Also be sure where the rotor is pointing, dist should only go in one way but if forced can be installed 180 out.
norville
01-30-2015 06:14 AM
gmattutorsam
03-28-2013 05:58 PM
jvdlcr125
01-13-2013 12:37 PM
elmerochingon
10-25-2012 11:21 PM
airguitarfish
07-10-2012 12:56 PM
