95 accord fuel guage and dr door lock
Old 04-14-2008 | 08:12 PM
batmangarysmith
Default 95 accord fuel guage and dr door lock
hi folks new on here and new honda owner.....95 with 222,231 miles, runs and drives great.however fuel guage only registers 1/4 of tank at the most even after filling up.is this a normal prob ? sound like sending unit or guage prob??? also the drivers door lock pops back up after i hit the lock button and shut the door. if im sitting in it with door shut , it works good. wont lock with key from outside either pushes up.....thanks for any help
Old 04-14-2008 | 09:02 PM
Drpepper's Avatar
Default RE: 95 accord fuel guage and dr door lock
Not sure on the fuel guage but the door lock is acting normally.
When you hit the power lock button from the inside you need to pull the handle at the same time. Or you can lock the doors by turning the key from the outside.
I think it is Honda's way to prevent accidental lock-outs
Old 04-14-2008 | 09:07 PM
Drpepper's Avatar
Whoops! Didn't see the last bit of your post "wont lock with key from outside either pushes up....."
Not sure what that problem is....But try pulling the door handle when you hit the lock button.
pmay805
03-16-2015 11:41 AM
Doublel
03-11-2013 08:57 AM
dre2430
04-22-2011 12:01 AM
djrockewfewtimez986
07-06-2010 06:34 PM
dwarez
10-11-2006 10:53 PM
