95 Accord Headlight problem. PICTURES.
Hey guy i am having a headlight problem on my accord.
when i plug the headlight in , it wont come on but , the the bumper signal and taillight signal turn on like a regular light , and the corner light doesn't turn on.
But when i unplug the headlight the corner signal turns on and the taillight works normal , but the bumper light turns off.
Help please??
Headlight Pluged in :
Headlight Unplugged :
Help please??
I had this problem on my 95.
Clean the ground that is on the bumper on the passenger side. You may have to jack up the front of the car to get easier access. It took me about 15 minutes to fix.
Download the 94 shop manual from one of the links in the online manuals thread in the DIY section. The electrical section shows the relay and ground location on your car.
It is a metal bracket with plastic connector with a bunch of black wires going to it.
I unbolted the bracket, used a dremel (you can use a file) to clean where the washer touched the bracket.
I cleaned as much rust off of the bolt and washer as I could.
#54 is the what the ground looks like. You can also get a new bolt from the dealership for less than $5.
I have the very same car and I did bolt the grounds or #54 and only the passenger headlight started working. I checked the bulb fuse.... also the blinker to that side blinks faster than the other.Checked the bulbs front and back...wtf this is frustrating...help please
EXplicit02v6
08-29-2012 12:14 AM
Paul79UF
DIY Answers.
06-16-2011 08:42 AM
elmillon77
11-18-2006 05:52 PM
djstylze
11-02-2006 02:08 PM
