95 Accord speedo
Old 04-22-2008 | 08:30 PM
Cee
Default 95 Accord speedo
Hi I'm new to this forum but I have a ? My speedo does'nt work they said it was a sensor so I changed the sensor. Is it possible that I need a new cluster because when you turn the car on it jumps to 20mph
Old 04-22-2008 | 08:49 PM
Default RE: 95 Accord speedo
If the cruise control still works while the speedometer is stuck at 20mph, then the speedometer is bad.
I had mine stuck at 20mph as well. I sent off my speedometer to a repair shop that I found online. I didn't want the mileage on the odometer to be different. It has worked flawlessly since it was repaired.
Old 04-22-2008 | 09:05 PM
Cee
Thank's for your help how much was it to fix your speedo & what site is this?
Old 04-22-2008 | 11:12 PM
If I remember right, it was ~$110. Honda wanted about the same price for a new one and they wouldn't roll the odometer to match my mileage. That is why I just had it fixed.
It was called Powls speedometer repair. I just googled speedometer repair shop, then called and asked if they knew how to fix the problem with my speedometer. They said that they could fix that. I'm not sure what they did.
chevync208
07-16-2009 11:16 AM
madsteez
10-28-2008 09:27 PM
spidremedia
09-12-2008 11:53 PM
GoJackets
07-26-2008 04:59 PM
cook393
03-01-2008 02:10 PM
Quick Reply: 95 Accord speedo
