95 Accord Speedo Intermitant
Cruise Control always work. Without solder the speedo circuit board the Speed always stay in 20 mph when I turn on the key. After solder the circuit board it comes to zero when key is turned on. Right now the speed problem is intermittent. Sometime is work sometime it does not. I believe this is the connection problem. Is anyone know which connector and which pin in the instrument cluster for speed control and where it goes to? I can not see it in the shop manual. Your help will be appreciated. Thank you for your reply.
If you're willing to try, this may be a possible fix:
Possible fix for 95-97 Accord speedometer circuit board - Honda-Tech
I got the answer
I found the circuit diagram of the instrument cluster. The vss to the speedometer is C12 orange wire. Vss has two wires; one goes to cruise control unit, another one goes to speedometer. If the cruise control works that means the vss is working. Definitely my car's problem should be the speedometer circuit board. Some people mentioned that some of the pin mold with epoxy has problem. I did not solder that area. I will do to see what happen.
The solder joints with the glue/epoxy is not the problem.
But if you want to remove the glue/epoxy, use a heat gun or hair dryer and heat the area up, then use a utility knife or x-actor knife to gently lift it off. Do a small area at a time, and the glue will lift off/break-out easily. Be careful with the knife to not accidently cut into any of the circuit board traces.
My picture in that thread shows the glue/epoxy removed.
Problem fixed
Thank you for all of the help. It is hard to remove the epoxy. Since my problem is intermittent, I do not think the solder in that area is the problem. Then I checked how the signal transfer from outside to inside I found the problem. The signal transfers from the screw area contact. Some one mentioned to re-solder the screw area and fix the problem. I found inside metal is the problem. I clean that area and put the solder to make the contact better and install back. Test drive. It is back to normal.
This is outside board at speedometer area.
This is speedometer circuit board.
The design of this instrument cluster is to use the screw to pass the current and signal from the outside board to the speedometer circuit board. Most of the speedo problem is caused by the contact of those four hole area. Look at the speedometer circuit board picture. You can see those area that I put the solder. I suggest you do not use solder like me because it burned my board. What you can do is to use the fine sand paper and sand it a little bit. Do not sand too much it may damage the contact surface. Then use the flat screw driver pop those four leaves of metal of each hole a little bit up. Also make sure the screw is clean. I believe it will fix your speedo problem. The reason is the vibration loose the screw a little bit and cause the spark in those area and caused the contact problem. Good luck.
Rtherres
01-23-2012 12:23 AM
Rtherres
04-11-2011 07:37 AM
Spdfrk1990
04-10-2008 03:54 PM
