95 accord won't start
Old 08-05-2016, 10:51 PM
The Toecutter's Avatar
Originally Posted by Iheartmyfa5
I can hear the fuel pump constantly running when I use the power probe to the fuel pump. But still no start. It will start every time with starter fluid. I'm convinced it's in the ecu because I've had it running under its own power a couple of times but now it just cranks. A guy I woke with, who has been a mechanic for 20 years and has a semi built 95 accord just like mine, thinks it has to do with my ignition tumbler (since its been by passed and has a push button start) I can't seem to find my volt meter to see where I'm losing power.
If it's not one thing it's another.
The thing is, if it'll start AND run on starting fluid, the ECU is good, the ignition system is good, and mechanically, the engine is good (it's still in time). If you can hear the pump run at all, it's good. This leaves you with either no power to the injectors, or no power coming out of the main relay to the engine systems(injectors).
Right now, since you've added a push button to start it, this means you've got more testing to do, so you can narrow it down a little further. If it still had the original ignition switch set up (no push button added), then I'd say the switch was still good. Yes, they can fail, but they do so intermittantly, and you can actually hold the key a certain way to keep it running. When the switch fails, it shuts down the engine (even starting fluid won't allow it to run) by killing power to the ignition coil. Right now yours is working, since it runs on starting fluid.
  #22
Old 08-06-2016, 12:46 AM
You definitely have a fuel problem.
The pump running doesn't mean that it is providing enough fuel pressure. The injectors may not be firing for several reasons (ECU, wiring, power missing at the injectors). You still need to test to figure out which.
Fuel pressure is probably the easiest test, but you need to find a pressure tester that will thread into the access port on the fuel rail. Maybe the parts stores pressure testing kits they loan out has the proper fitting.
If you have a volt meter, see if you have power going to each injector with the key in the II position. The wire color you want to test will be the same on each injector and I think it is red. For ground, use a valve cover bolt. The other color wire at each injector is grounded by the ECU to open the injector.
  #23
Old 08-06-2016, 01:51 PM
Iheartmyfa5's Avatar
Thanks PAHonda! I'll test for power to the injectors tomorrow since I can't find my volt meter I'll borrow my dads. ��
And I didn't install the push button, I bought the car the way it is with the existing problems. But hey, it was $300...can't complain too much. Hopefully I'll have it figured out this weekend and get this thing on the road (it's time to park my si)
  #24
Old 08-08-2016, 09:22 AM
The ignition switch only has a couple circuits. If that were the problem, you wouldn't have spark - and you apparently have spark to ignite the starting fluid.
Certainly check power to the injectors. But if they don't have power, it's in their circuits not the ignition switch.
  #25
Old 08-09-2016, 05:59 AM
Turtlehead's Avatar
Check the resistance of the injector resistor. Terminal 1 is power so check between no. 1 and 2, 3, 5 and 6. Each should be between 5 and 7 ohms. If there is no power to terminal 1 with the key in the RUN position then fix power issue. It is not uncommon for the resistor to fail.
  #26
Old 08-11-2016, 10:40 PM
This was what I was trying to get across. I ran into this myself only a couple of months ago on my own car. In my case, the PO told me he thought the fuel pump was dieing, but it started right up for me after having been sitting for 3 weeks to a month (wouldn't start for him in that time frame). I drove it home, and the next day it wouldn't start. I chased the entire electrical system for a month, until I finally found I didn't have power to the injector resistor pack. The resistor pack did ohm out just fine, but no 12 volts going to it. Once I brought power over to it, it fired right up and ran just fine.
  #27
Old 08-15-2016, 08:10 PM
djkurious's Avatar
Just wondering, where did you run 12v from the the power wire of the resistor box? Ignition 12v?
  #28
Old 09-14-2016, 01:56 PM
Hey guys, ive been steadily checking things off the list of what my problem could be.
Main relay - good
Fuel pump - good (only when using a power probe)
Injectors - not working (haven't figured out why)
Ecu - haven't figured out what exactly I need to test
Injector resistor pack - good
Ignition switch is still a question mark since it still has push button crap
Fuel pressure - good
Any help on what specifically I should test in the ecu to tell if that is my problem or any other ideas would be greatly appreciated!
  #29
Old 09-14-2016, 03:57 PM
I could not find where you have verified 12V power to the injectors. Power should always be available. Injector fires when a ground signal is sent to injector by ECM. Both power and ground can be confirmed w/ a noid light hooked to injector/s.
Tony1M
11-06-2023 08:29 PM
maso5219
12-05-2015 09:09 AM
Sheri6889
06-17-2015 08:19 AM
dgeorge
11-29-2004 01:40 PM
Quick Reply: 95 accord won't start
