95 ex Honda Accord parts on ebay
Old 10-18-2008 | 11:50 PM
d_zone21
Default 95 ex Honda Accord parts on ebay
95 honda accord ex (4cyl), I need to buy VSS(variable speed sensor) and crankshaft position sensor, i went to autozone and it cost $150 and i looked at ebay for $25. is it ok to buy it at ebay? is it as good as the at autozone? crankshaft position sensor cost over $150, is there a website i can go too that is reliable at a reasonable price?
Thank you
NEiser
Old 10-19-2008 | 11:33 AM
brayner's Avatar
Default RE: 95 ex Honda Accord parts on ebay
buying from ebay is riskier than buying from a local retailer. You may end up with no recourse if problems occur. I can tell you from experience that the Ebay company will not lift a finger to help. That being said, most of us have had good luck with ebay.
The parts are mostly cheaper, made in China. I have purchased Honda genuine parts on ebay. Each part will need to be investigated. A $25 part is unlikely to be the same as a $150 part.
Remember- you always pay for what you get, sometimes you get what you pay for
Old 10-19-2008 | 12:17 PM
I have purchased several VSS from ebay for about $25. One only lasted about a year, but I swapped some parts from new VSS to old VSS body so problem could have been mine. I did this on an Acura TL w/ a unique VSS body shape but same internals as Accords, et al. DoctorAutoParts was vendor and they shipped promptly. I don't think the Honda product at $125 is worth that much extra, but it likely is a higher quality product.
I suspect some VSS problems are simply due to excess lube grease (inside VSS) blocking the signal between magnetic rotor and sensor. It might be worth cleaning, lightly lubing w/ silicone grease,and re-installing the sensor rotor (remove 3 top screws to expose rotor). I plan to try this on my next VSS fault. VSS is a common fault w/ Honda/Acura products.
wattsk69
05-17-2012 10:16 AM
St.George
10-08-2010 11:01 AM
top end ms
02-14-2008 01:35 AM
comptoncarl
02-08-2007 04:04 PM
Adie
03-24-2006 10:26 PM
