'95 EX Sedan, 22mm or 25mm sway bar??
Does anyone know the standard sway bar size in an 1995 EX Sedan? The Energy Suspension bushings come in either 22mm or 25mm. To confuse things worse, I just spoke with a Honda dealership and they say the standard rubber bushings are 27mm. Could the rear bar be a different size diameter than the front? I'm working on the front bar. Could the polyurethane products be 25mm because they fit tighter?
RE: '95 EX Sedan, 22mm or 25mm sway bar??
Well, I called Energy Suspension directly and"Matt" said that Honda used both sizes those years and the only way to know is to get under the car and measure the bar.
If anyone needs to order Energy Suspension parts,he recommended calling "Bruce" at Suspension Warehouse: 800-291-5340.
