95 honda accord ex vtec manual 5 speed over temp issue
Old 03-29-2012 | 12:26 PM
anti3025's Avatar
Default 95 honda accord ex vtec manual 5 speed over temp issue
Ok, I got a excellent deal on this car, $500.00 has after market header, custom exhaust all the way up, and good cold air intake, I bought it for a project car, but it is over heating, motor sound and feels great, I noticed that the temp gauge works but only go's up to right below normal even though the car is over heating so because the temp gauge is just right below normal the fans dont kick on, Any suggestions, I am thinking a sensor, But i am going to go ahead and replace the water pump and timing belt while i am at it since it dose have over 100k miles and thermostat, I am also wondering if the water pump is not working completely so there might be air in the lines and dose not allow the sensors to read correctly? Any suggestions welcome and Pic's of any sensors i need to check Thanks in advance!
Old 03-29-2012 | 12:49 PM
crispin's Avatar
run the car, open the bleeder valve until coolant comes out.
Bleeder valve located where lower radiator hose connects to intake.
Old 03-30-2012 | 03:11 PM
anti3025's Avatar
Default opening the bleeder valve
Thanks for the reply tried that but I could not get any fluid to come out of the bleeder valve,,,,,hum stuck thermostat?
Old 03-30-2012 | 03:55 PM
crispin's Avatar
did you hear air hissing out from the bleeder valve when you had it open?
Old 03-31-2012 | 08:24 AM
Are you sure the coolant is full?
Car off, open the heater control valve (use **** to max heat or manaully), pull the bleeder all the way out (check that it is not clogged), remove cap. Be sure the coolant in the rad is full. Add if needed, should start to come out of the "hole" where the bleeder was. Install bleeder after you cleaned it. Try the bleeding again.
Old 04-01-2012 | 03:47 PM
anti3025's Avatar
Default At work will try it tonight
Ok, I did not hear any air hissing when i had it opened the last time. I will try again tonight and let you guys know
Old 04-01-2012 | 11:33 PM
02skyline_R34's Avatar
If your rad is full, check your sensor. It could be faulty, giving you a normal reading when it is actually hot
Cjohnson700
03-29-2013 06:46 AM
zZHellBlazerZz
06-15-2011 10:12 AM
gsawyers
04-12-2010 10:42 PM
raf105
09-28-2007 02:55 PM
Quick Reply: 95 honda accord ex vtec manual 5 speed over temp issue
