95 LX catalytic converter
Old 12-30-2011 | 07:41 PM
gk95's Avatar
Default 95 LX catalytic converter
I replaced the original CAT (155,000 mi) w/a magnaflow replacement. The replacement may not have been the correct part. It fits as far as length & mounting brackets go, but did not have a flange to mount the hanging support on to. After mounting the replacement, as well as adding exhaust hangers to the middle hanger studs & using exhaust straps to attempt to stabilize the forward support bracket the fix makes more noise than the old CAT w/broken heat sheild.
Would it be feasable to hollow out the old CAT & remount it? Also could the rubber exhaust hangers added, when there were none be causing the increased vibration?
Old 12-30-2011 | 08:10 PM
Is just the heat shield bad on the old catalytic converter?
Old 12-30-2011 | 08:11 PM
gk95's Avatar
Yeah the heat shield was broken away from all but 2 bolts top & bottom. Due to milage & not owning the car for long I decided to replace the cat.
Old 12-31-2011 | 08:44 AM
Would replacing/fixing the heat shield be out of the question.
HondaLawgik
02-24-2011 01:14 AM
thunder_x
06-03-2006 07:27 PM
94exsedan35094
05-20-2006 03:42 AM
St3v3
05-09-2006 01:53 AM
msmcv73
03-27-2006 06:49 PM
